bcm
Old Aug 28, 2012 | 03:19 PM
dave countie jr's Avatar
Default bcm
hi kids, where is the BCM on my 04 ss?
Old Aug 28, 2012 | 04:00 PM
01 Monte SS's Avatar
It's on the drivers side above the parking brake lever. Under/behind the dash.
I believe this is the correct diagram
Old Aug 30, 2012 | 02:31 PM
thanks 01. how much do these things set u back, and do u have to have a stealer install it?
Old Aug 30, 2012 | 04:05 PM
Looks like rockauto has them for $120-140 new. Requires a re-learn after installing. There's a few good links here on the site that can help you out with the re-learn process if you're comfortable doing it yourself. I've never had to replace mine but I'd do it myself before taking it to a dealership. No clue how expensive it would be to install.
Also, rockauto has a discount code for 5% off ===> https://montecarloforum.com/forum/ve...-2012-a-37575/
Old Aug 30, 2012 | 06:28 PM
aussiek2000's Avatar
Good luck doing it yourself. It's best to re-program it with the techII since you have to set up passlock any way.
Old Aug 30, 2012 | 09:22 PM
Dave Morejon's Avatar
just had mine done a few months ago at the dealer and it was around 400 to 500 cant remember the exact amount
Old Aug 31, 2012 | 03:39 PM
Omg i cant see why everything is controlled by this. its like Colossus, The Forbin Project. it got a mind of its own and if u dont do what it wants it will shut down EVERYTHING.
1stz51
Aug 18, 2019 03:18 PM
5Ringz
May 8, 2009 08:03 PM
dustybird3
Apr 1, 2009 11:57 AM
willie8701
Mar 30, 2008 08:46 PM
willie8701
Mar 28, 2008 10:18 AM
