6th Gen ('00-'05): Battery light stays on after car shut off
Old May 2, 2015 | 07:41 PM
cmbiz1's Avatar
Default Battery light stays on after car shut off
After I shut off the car and remove the key, the battery light and the gear shift indicator light remain on and the battery drains. Is it possible the switch is not completely off enough though I can remove the key? I was thinking it might be the switch.
Any help would be greatly appreciated.
Old May 8, 2015 | 06:28 PM
cmbiz1's Avatar
About 30 seconds after I shut the car off, I hear a click when the headlights go out and then the gear shift light comes on and stays on until the battery drains. Is it possible the headlight switch is going bad?
Old May 8, 2015 | 10:11 PM
What year? model,(LS/SS) Motor etc..
How many miles on it?
Old May 9, 2015 | 02:50 PM
cmbiz1's Avatar
03 SS 3.8 with 198k. All stock except radio. I used the correct adapter to match the wires. It was working fine until recently. I disconnected the radio (thinking it may be the cause) however it did not help any. There are no codes
Old May 17, 2020 | 11:43 PM
Marlik Moses's Avatar
Default Did you ever find the problem
[QUOTE=cmbiz1;661900]03 SS 3.8 with 198k. All stock except radio. I used the correct adapter to match the wires. It was working fine until recently. I disconnected the radio (thinki
key
Nov 15, 2021 12:48 PM
farmerjg
Jul 6, 2014 09:07 PM
Perry Mason
Jan 9, 2013 12:13 PM
Furder2010
Feb 14, 2012 08:34 AM
rob559
Feb 22, 2007 11:13 PM
