6th Gen ('00-'05): Battery drain. Help!!!
Old Mar 6, 2015 | 07:50 AM
Bultemeier32's Avatar
Default Battery drain. Help!!!
Okay got a 2000 Monte carlo ss and just replaced all coil packs, spark plugs, wires, and also the alternator and the battery!! What else could drain the battery. All of that was fixed 5 days ago and it has ran perfectly fine and nothing was wrong and I went out to start my car this morning and the battery was dead. Please help
Old Mar 6, 2015 | 08:32 AM
Pearl2000's Avatar
Good Morning, probably wont be much help, but is it possible you got a bad battery?
Old Mar 6, 2015 | 08:42 AM
Make sure you check all of your connections and grounds for your battery & alternator.
Old Mar 7, 2015 | 04:39 AM
claydoh's Avatar
I have had several batteries that ended up with a bad cell that would be fine, then not! even when tested!!
Old Mar 16, 2015 | 06:37 PM
SLaFlame's Avatar
Had the same issue with my 03 ss. After replacing the battery, alternator, and starter the problem went away and the car starts every time.
Old Mar 17, 2015 | 08:16 AM
Default battery was the problem
I had the battery for about 6 days and took it to get tested at advanced and the problem was a bad cell inside of the battery. It had 0 amps when it was tested.
RonBGA
Nov 20, 2012 09:14 AM
ddschneider1972
Oct 24, 2007 07:32 PM
lakeman_21
Sep 29, 2007 01:58 AM
2000_BLACK_SS
Feb 14, 2007 05:42 PM
newbie
Dec 17, 2006 10:11 AM
