Balance Shaft
Old Dec 31, 2013 | 11:20 AM
turbo monte's Avatar
OK your doing this in a 5th gen so I don't know about any clearance issues for headers. To use a gen v all you have to do is buy the gen v to l67 throttle body adapter plate from Zzp. Keep in mind to use the gen v you need the gen v lower intake and a gen v intercooler because the gen 3 stuff won't work. In all honesty I suggest just buying a gen v top swap used on the forums and top swap your existing engine.
Old Dec 31, 2013 | 11:21 AM
The l32 heads (series 3 engine with the gen v) flow better than the l67 heads also.
Old Dec 31, 2013 | 11:56 AM
djhixter's Avatar
i am seeing more cha ching coming out of this build now LOL
Old Dec 31, 2013 | 12:53 PM
Lol yea it gets expensive. If you have any other questions feel free to ask
Old Dec 31, 2013 | 04:14 PM
djhixter's Avatar
thank you turbo...i appreciate your advice...can't wait to get this project started and seeing what she is going to do
Old Dec 31, 2013 | 04:37 PM
welcome man, im glad i could offer some help. keep us posted on your build and even make a "build thread" if you want so we can all follow your build
Old Dec 31, 2013 | 04:42 PM
djhixter's Avatar
i sure will...and thanx again...i'm going to try to post at least a pic of what she looks like now since she was lowered from the suspension i took off of my lumina
Old Jan 11, 2014 | 06:17 PM
Overkill's Avatar
Just remove the balance shaft gear to disable and you're done. I agree with leaving it in the motor, only way I'd remove it is if the motor was being rebuilt and you had the opportunity to drill/tap the feed with the rear cover off.
I ran the LS6 (now LS3/LS9) valve springs on an XP cam for several years, zero issues, no need to go overboard on the valve springs. They'll also be easier on the lifters, rocker arm trunions and valves.
Have the Rollmaster crank gear machined in back to match the stock gear as turbo mentions. Check the clearance from the #1 main cap to the chain teeth, you want it to match the stock gear. Then hold a straight edge from crank gear fully seated to the camshaft with cam gear installed, ensure the cam isn't pulled all the way forward for the gears to line up. If the back of the crank gear is machined, you'll have clearance from the oil pump cover, no need to get the machined cover, that's only to compensate for the actual issue of the crank gear not being machined correctly. Cam gear clearance issues only result when the cam gear, sitting too far away from the block, pulls the camshaft forward out of the block and touches the front cover (I've seen the cam retainer plate crack as well); again with the crank gear machined properly, no need to double gasket the front cover, just use an OEM paper gasket, the FelPro gasket is metal and thinner than the factory paper.
HTH
Old Jan 14, 2014 | 02:51 PM
l67ss's Avatar
On fifth gens the main header clearance issue is the firewall.
Old Jan 14, 2014 | 06:14 PM
djhixter's Avatar
i TOTALLY agree witht the clearance on the firewall...that is one reason why i am putting zzp's 1" shorter dog bones, along with a little bit of axle bind that i have been experiencing when i lowered the car...i had the same thing on my lumina, when i lowered it, but i never put the shorter dog bones in, because i had the lq1 engine...
monte carlo 3831
May 9, 2012 05:01 PM
Gib DTD
Dec 23, 2009 01:57 PM
dominic
May 26, 2009 01:08 PM
bizzo
Mar 26, 2007 04:52 PM
01blackmonte
Oct 17, 2005 07:30 PM
