transmission service
Old Jan 9, 2014 | 05:32 PM
dgm's Avatar
dgm
Default transmission service
gonna do a trans service - anyone hear anything about dextron 6 - what are you using?
Old Jan 9, 2014 | 05:41 PM
l67ss's Avatar
What year car do you have?
Old Jan 9, 2014 | 05:51 PM
Dex6 is an upgraded version of dex. It is compatible with Dex3 cars and should keep cooler than usual.
I have Dex6 in my transmission
Old Jan 9, 2014 | 05:52 PM
dgm's Avatar
dgm
2000 ss
Old Jan 9, 2014 | 06:00 PM
l67ss's Avatar
Only downside to dex6 is that its thinner, if u already have problems(or a lotta miles it could cause to slip or leak
Old Jan 14, 2014 | 11:18 AM
djhixter's Avatar
make sure that you are completely flushing out the current dex III when going to dex vi...may as well change the filter as well
Old Jan 14, 2014 | 12:03 PM
If you check the service information, GM does state you CAN mix DexVI with DexIII and no issues.
And I would recommend you pan drop and do a fluid and filter change on the trans. I'm not a fan of flushes.
Keep in mind, pan dropping will not change the fluid in the torque converter. Some view it as an issue, I never have.
Old Jan 14, 2014 | 12:24 PM
djhixter's Avatar
while i totally agree that you can mix dex III and dex VI, if your dex III is dirty and contaminated, you are going to contaminate the new fluid you are going to add...on the other hand if you have over 100k miles and the trans has NEVER been serviced, i would not do a flush...
Old Jan 14, 2014 | 01:48 PM
owens91's Avatar
When I did the fluid and filter change I put in dex 4
Old Jan 14, 2014 | 02:22 PM
Hiroska's Avatar
I never serviced mine ;/
