Wiper motor
Old Sep 17, 2008 | 07:09 PM
aroman's Avatar
Default Wiper motor
Wipers not spitting out fluid and yes the reserve has fluid
Wipers work tho ...
Anyone have any idea that it might be something else ?
If not this seems like a lot of labor to fix..(probably more labor cost then the part) How much you think it should run about all together?
Old Sep 17, 2008 | 07:10 PM
aroman's Avatar
Default RE: Wiper motor
this is a 06 monte lt by the way
Old Sep 17, 2008 | 07:17 PM
mrl390's Avatar
Your washer fluid pump is probably bad or the power supply to it is bad. Either that or a hose has come disconnected. Check the fuse to the washer pump first. If thats good, disconnect the hose coming out of the pump and have someone turn the washers on. If it doesnt squirt out fluid (fluid should flow out on its own anyway, but it will be pressurized if the pump is working), the pump is probably bad. The wiring to the pump could be bad too, but unless you have or know someone who has a multitester, you cant really safely test to see if it has power.
If you do have to replace the pump, its not a hard job at all. Just unplug the pump and pull it out. If youcant get to it while the bottle is in,remove the bottle and pull out the pump. You can get a new one at the auto parts store for pretty cheap.
Old Sep 17, 2008 | 08:47 PM
aroman's Avatar
Thank you for the info. Changing battery tomorrow so I will be in that area. Hopefully all works out.
Old Sep 18, 2008 | 07:55 AM
aroman's Avatar
ORIGINAL: mrl390
Heh, including removing the front bumber, only really way to access it , unless I'm doing it wrong
Old Sep 18, 2008 | 09:44 AM
aroman's Avatar
guess it is not really hard to remove, besides the last screw on each side near the wheel well.
after that was easy ...
Fixed, Thanks
brecker57
Aug 4, 2011 06:42 AM
brecker57
Aug 2, 2011 06:27 PM
montemike88
Aug 2, 2011 05:25 PM
Vladimir
Apr 1, 2011 12:23 AM
reelez
Feb 14, 2011 11:16 AM
