Axle shafts
some have a splined peice that may have fallin into the bottom of the case when the old ones where removed, otherwise its just a clip inside and you just have to use a little force to "pop" the axleshaft into the differental case
a dead blow hammer should help get it in there........but look inside the "holes" to see if there is anything obstructing them from going in
2003supersport
05-13-2010 01:24 AM
dagrease22
07-21-2007 08:43 AM
