6th Gen ('00-'05): Aluminum UIM
Old Mar 15, 2014 | 03:13 AM
Zeldar's Avatar
Default Aluminum UIM
Does anyone know where I can purchase an aluminum UIM plenum? I cracked the factory plastic one, also what could happen as a result of driving it with a crack in it right next to the throttle body where an uim bolt goes..? Any responses are appreciated this is my first question as a member thanks.
For a 2003 SS 3.8
Old Mar 15, 2014 | 03:37 AM
turbo monte's Avatar
Search junk yards is your best bet. These are not a direct bolt on intake but can be made work for sure, I've did it on turbo monte.
I would advise against driving it with a cracked uim. If it's cracked it's a vacuum leak etc which is not good.
Old Mar 15, 2014 | 05:43 AM
Hello, like Turbo Monte says, the aluminum upper intake manifold we use on our engines is not a direct fit and will require a fair bit of modifications from you to make it fit on your engine. The manifold comes from the Buick L26 engine.
Here is a link to an eBay listing so that you may see the part your looking for, and as Turbo Monte said would be available from a junk yard at a fair price fi you live in the proximity of one.
Click on the link below for eBay listing:
2006 05 11 Lucerne 3 8L Vin 2 8th Digit Opt L26 Intake Manifold 12598924 | eBay
Old Mar 15, 2014 | 09:56 AM
Zeldar's Avatar
Cool thanks guys
Old Mar 15, 2014 | 01:56 PM
PacerSS's Avatar
I've got two in my garage. PM me if you want to buy one.
03JGMonte
36
Aug 25, 2012 03:49 PM
BlownUptoHigh
Mar 29, 2012 10:32 AM
rpoppaw09
17
Mar 21, 2012 10:18 PM
forgotten
15
Jan 27, 2012 05:16 PM
red04montels
19
Feb 12, 2011 04:58 PM
