UIM gasket & fuel rails
Whats the best UIM gasket to get? & can i remove the lower intake without taking anything else off? & how should i go about removing the fuel rails? Thanks
and you have to remove the fuel rails and any wiring that may be in the way. the fuel rails are on with 4 10mm nuts (im 99% sure) lol then just carefully pull it up and move it out the way. or you could disconnet the lines, which is really easy
Anyone got part numbers for good gaskets?
I think all UIM gaskets are nylon. But for the LIM, I would NEVER use anything but a aluminum gasket these days. FelPro makes them. I advise ordering them via RockAuto. I think a LOT of the info with pics you can find in this thread Frank started a while back:
https://montecarloforum.com/forum/en...te-dead-37916/
you should also paint your UIM
