5th Gen ('95-'99): Strange sound after Uim replacement
Old Mar 25, 2012 | 01:23 PM
BlownUptoHigh's Avatar
Default Strange sound after Uim replacement
replace the uim with dorman one and added a hv3 insert a couple of week ago, but now i hearing this strange sound when i shut off the car. i had problem closing the pcv cap so i thought where the noise was coming from so i bought a new one and got to close properly but it still making the same noise from the same spot somewhere near the pcv cap but it coming from inside the uim
Old Mar 25, 2012 | 05:59 PM
03SSLE's Avatar
Does the pcv valve in your engine require an o-ring, and if so is it installed and seated properly?
Old Mar 26, 2012 | 12:39 AM
yeah i bought a new pcv kit and installed it and it comes with the o-ring
Old Mar 29, 2012 | 09:16 AM
yeah i wondering if i should my old gm uim back on because the pcv cap is not sitting on there tight with both o-rings. Even though i got the cap on properly you can still a slight space and i guess air is escaping through there when the car shuts off
Old Mar 29, 2012 | 10:32 AM
I don't believe the HV3 is compatible with the Dorman UIM
03SSChevyFun
Apr 23, 2015 01:38 AM
03_MONTE SS
Feb 24, 2013 10:30 PM
silverodo12345
Jan 9, 2013 02:41 PM
echoingvoid
Sep 20, 2009 01:08 AM
weizie
May 15, 2009 05:56 PM
