an aftermarket PCM you would most likely recommend...
Old Jul 3, 2009 | 02:35 AM
vincenti's Avatar
Default an aftermarket PCM you would most likely recommend...
is manufactured by...? I'm looking for something to eliminate the top speed limiter on my '98 Z34. and before anyone starts harping on me about "why you wanna go so fast?" I don't. I just want the piece of mind of knowing that bugger is gone. thanx yinz guys.
Old Jul 3, 2009 | 11:04 PM
thewhitestcarlouknow's Avatar
I have a PCM from ZZP and really like it. It removes the limiter as well as a bunch of other stuff. It was like one hundred dollars but if you have had a problem with your cat and need the code deleted it is worth it.
Cowboy6622
Aug 1, 2013 10:17 PM
SSmeansSuperSexy
Dec 7, 2011 02:55 PM
jeffsmonte
Jul 19, 2010 08:04 PM
sinceire
Jun 30, 2010 06:28 PM
knightfan26917
May 7, 2008 06:48 AM
