Ac Compressor bearing
Old 03-05-2012, 11:50 AM
Silver SLP's Avatar
Default Ac Compressor bearing
So my AC compressor bearing is shot and it makes an awful noise. However sometimes it will be completely quiet. I know a new compressor is very expensive and the bearing is only about $14.
I saw a few re-man compressors on ebay for about $75 and I've checked with a lot of local shops and they wont just replace the bearing.
I'm assuming I'll have to get the AC recharged as well? I want AC this summer so the bypass pulley isn't an option. What would be your recommendation?
Thanks for the help!
Old 03-05-2012, 11:52 AM
Sounds like metal rattling when the compressor isn't engaged?
Sound goes away when your turn the A/C on or the Defroster on?
That would be the AC clutch starting to go. A little WD-40 (avoid the belt) will most likely make it go away.
You could also use a puller and pull the clutch away a tiny bit and the noise should go away. Though I just used the WD-40 method.
Old 03-05-2012, 12:01 PM
Silver SLP's Avatar
I'll try the WD-40 this weekend when I get home from school. Thanks!
-yeah when I turn the defrost on the noise will go away but then if I give the car gas sometimes it will come back again without changing any defrost settings.
Old 03-05-2012, 12:31 PM
It might not be a PERMANENT fix, but it can give you time to save up money.
Both of my cars did it this winter, I did the WD-40 and I'm about 4 months without ever hearing it again.
I did it first with the Camaro since I care more about the Monte, and nothing seems harmed haha
Old 03-05-2012, 01:27 PM
Silver SLP's Avatar
Haha classic! So just spray around the pulley?
Old 03-05-2012, 01:37 PM
Spray around the pulley (where it spins) and the very center with the car running and the compressor engaged.
Old 03-05-2012, 01:39 PM
Silver SLP's Avatar
Okay thank you!
Old 03-05-2012, 01:43 PM
No problem! Remember a little goes a long way, you should see it basically get sucked in while you spray and then when you disengage the compressor the noise should be gone
motivation2k3
09-29-2008 03:58 PM
motivation2k3
09-29-2008 08:22 AM
smolek37k
08-06-2008 08:36 AM
nitehwk10
04-26-2008 02:46 PM
SophicSage
07-24-2005 03:29 PM
Quick Reply: Ac Compressor bearing
