Opinion Needed: ABS Probs
Old Nov 7, 2018 | 07:02 AM
ajay654's Avatar
Exclamation ABS Probs
Hey Everyone,
My 2004 Monte is having a ABS issues. Seems like randomly when I brake or brake while turning the ABS, trac off, and service trac system lights come on. It is not all the time, kinda random. About a year ago I took it to a tech for the same problem and they replaced 2 ABS harnesses. Seemed to fix the problem till just recently. Could it be the same thing, or something else?
Thanks in advanced.
Old Feb 21, 2019 | 11:09 PM
cortesjr's Avatar
you figure your prob with your abs? im having the same issue
Old Feb 26, 2019 | 07:59 AM
Throttle98's Avatar
Hello,
I am fighting the ABS and Traction Off lights on my 2001 SS also. First ABS code was for RR wheel speed sensor, I replaced that hub and it fixed it for about a week. The next time it came on I started checking wires and found that the LF wire harness was broken. I have since replaced both front and the rear wire harnesses and have yet to fix the ABS light.
Not sure what the next step is but if I have a breakthrough I will let you know!
Old Feb 26, 2019 | 09:10 AM
cortesjr's Avatar
i haven't looked around at the wire but seems like the moment i move or put in drive or reverse it comes on but its not all the time so im thinking if its a broken wire it would be a constant thing
Old Feb 28, 2019 | 12:04 PM
nitehawkjcb's Avatar
It could be a bad hub/wheel bearing assembly.
ajay654
Jun 25, 2020 12:09 PM
ajay654
Nov 16, 2018 01:54 AM
keithtaylor04
Feb 13, 2016 12:07 PM
claydoh
Jul 31, 2014 03:03 PM
michelob
Apr 16, 2014 10:05 PM
