6th Gen ('00-'05): abs/trac/service traction
Old Jul 27, 2014 | 02:30 AM
claydoh's Avatar
Default abs/trac/service traction
Hey guys,I have searched post and threads on this subject but found none describing what mine is doing! I have replaced both front wheel hubs but still get intermittent "ding" abs/trac off/service traction control lights. I know I probably need to change out both rear wheel hubs but heres the thing... I get a Humm,like pump running intermittently at all speeds,with or without brakes applied and when it does it while the brake pedal is applied I get a weird noise and feel from brake pedal!! after a while I get the "ding ding" and the lights come on and after that everything works fine.when I stop and turn the car off and restart,it goes away and then starts again?? could this be the ABS module/pump running issue like I see in the banner ads for $ 79 airbags ad on this site?? help! aggravating as hell!!
Old Jul 27, 2014 | 05:59 AM
Tobian46's Avatar
My car does the same thing. That vibration / humming is your abs pump running. I found out that the harness between the plug on the center hub and the actual abs module has a broken wire in it. Ive just been too lazy to fix it, that and the harness is like 100 bucks. So every now and then my abs pump goes off as if im sliding across a sheet of ice. To make a long story short the abs and traction control work together so when theres a problem with one they both go. I have no idea why the abs pump does this but looking for a broken harness is a good start.Hope this helps!
Old Jul 27, 2014 | 09:37 AM
gasman's Avatar
Happened to me in winter time... Had no traction at all
Old Jul 27, 2014 | 09:30 PM
Aaron0313's Avatar
First thing I'd do is if you have the ABS/Trac lights on is get the car code scanned at a local place like advance auto parts. They should be able to read the code for it and at least point you in the somewhat right direction. They do it free in every state but California to my knowledge.
Old Jul 31, 2014 | 02:44 PM
dave countie jr's Avatar
its the wire that goes from one of ur wheel sensors up through the shock tower mine was on the r side some how this wire gets rubbed an causes a short replaced it and haven't had a prob since
Old Jul 31, 2014 | 03:03 PM
btw my car is an 04 ss it cost me $65 bucks at meineke
michelob
Apr 16, 2014 10:05 PM
teamfbody
34
Aug 11, 2013 08:22 PM
Jokers1995
Jul 31, 2012 09:11 AM
