6th Gen ('00-'05): Need a bit of help figure out the wiring for the stereo
I have an 03 Monte Carlo LS im trying to put an aftermarket head unit in and I have found the wiring diagram for it but I cant figure out what the second plug is for it only has two wires coming from it and they aren't listed on the wiring diagram I have.
Last edited by Jebb; Feb 27, 2019 at 06:35 PM. Reason: Fixing a word so it doesn't cause confusion
The factory radio has the antenna wire, a large rectangular plug (which is the main one) and then smaller plug (almost square). That smaller one handles wiring for OnStar and/or XM to the factory radio. You should not need to worry about that last plug.
