Problem with car idling and running rough!
Old Jan 12, 2014 | 02:53 PM
SouthCarolinaSS's Avatar
Default Problem with car idling and running rough!
I have a 2001 Monte Carlo SS with 127,000 miles and the other morning my car started idling really rough. So I started to pull off and it was kind of "spurting" as I was getting to speed. I checked the codes and it brought up P0302, P0481 and P1404. After some research I ended up replacing the EGR valve. That got rid of the P1404 code. I know the P0481 is a cooling fan circuit, so that's not the problem. And the other code is a cylinder 2 misfire. Once I get up to speed it smoothes out but sitting still it runs real rough. Even when I put it in neutral when stopped its stops shaking. Does anyone have any idea what this could be?
Old Jan 12, 2014 | 03:26 PM
I'm going to advise a tune up.
Plugs wires. You may also be experiencing a clogged/clogging catalytic converter. Could also be water in the fuel (condensation). In the gas.
xxfallen-comradexx
Jul 17, 2014 09:29 AM
tps221
Oct 3, 2012 10:47 PM
Crazy4408pac
13
Aug 5, 2012 05:53 PM
RR CHOPPA
Oct 29, 2010 12:07 AM
bwill987
Feb 26, 2010 08:27 PM
