87 Monte Carlo ss With 454 motor
Old Oct 5, 2012 | 02:51 PM
Gus454MonteC's Avatar
Smile 87 Monte Carlo ss With 454 motor
Hey guys I want to know if any of you have a Monte C ss with a 454 in it and if 70's longtube headers would fit in my Monte C ss.
NOTE: Im 19 and im on a real real tight budget to build this car.
Old Oct 5, 2012 | 03:13 PM
Hi `Gus & Welcome to the MCF
Do you presently own a 4th Gen with a "454" c.i. ?
What type of longtube headers do you have or want to put on ?
Check back later also to see what are expert motorhead member's post of your questions...
Until then ? check the below links (Good Luck) Oh, pictures please & more details...~> Please post
If you don't get the answer you need..You can email/call any of the below.....
  • Hedman Hedders Headers
    <CITE style="FONT-STYLE: normal; COLOR: rgb(0,153,51)">SFX Performance Parts and Auto AccessoriesHedman Hedders</CITE>
    Engine size 396-502 without AIR fittings with emission fitting, 1965-1974 Chevrolet ...Impala Auto/Manual, 1970-1977 Monte Carlo Auto/Manual, 1968-<WBR>1979 Nova Manual ...1965-1982 Chevrolet Corvette, 396ci, 402ci, 454ci, 502ci, Also Option Using .... 1978-1987 Buick Regal, 1984-1997 Chevrolet Astro Van, 1971-1994 ...
  • Monte Carlo: ID that SS
    <CITE style="FONT-STYLE: normal; COLOR: rgb(0,153,51)">darklair: main pagemonte/SS.id.html</CITE>
    First off, there are two separate generations of Monte Carlo Super Sports. ... The Super Sport option's engine upgraded to a LS5 454 V-8 rated at 365 horse- power. ... 70 and 71 Super Sports break down as follows: 1970 2 Door Sport Coupe SS 3,823 454 ci V-8.... =====Sources "Chevrolet Monte Carlo 1970-1988 & 1995 .
  • JEGS Tubular Headers - JEGS
    <CITE style="FONT-STYLE: normal; COLOR: rgb(0,153,51)">www.jegs.com/p/JEGS-Performance-Products/JEGS-Tubular.../-1</CITE>
    ... Block Chevy 265-400; For Front (except engine-centered) Crossmembers; 1-5/<WBR>8" Primary, ... Painted Long Tube Headers; Big Block Chevy 396-454; 1964-74 Chevelle ...Block Chevy 265-400; 1978-87 Malibu, El Camino, Monte Carlo, Grand Prix, ...Painted Short Headers; GM 5.0L/5.7L; 1988-95 Chevy/GMC 1500/<WBR>2500 ...
Old Oct 5, 2012 | 04:09 PM
What brand are they?....But there shouldnt be any reason for them to not fit...Unless there not for an 87 MonteCarlo...
Headers are NOT a universal fit item.....
What are they from?
Otherwise....They WONT fit....
Old Oct 6, 2012 | 08:25 AM
03SSLE's Avatar
Since the BBC was not an engine option in '87 it's doubtful that the 1st Gen headers will be a bolt in installation. You may get lucky, but the only way you'll know for sure if they'll fit or not is to do a mock up. Someone might offer custom headers for a BBC swap, but I didn't find any for an '87 Monte Carlo in the quick search I did. You may end up having to alter the routing of the 1st Gen headers or have some custom ones made. But I don't know if that will work into your budget...
Old Oct 6, 2012 | 10:53 AM
Zen's Avatar
Zen
They do make BBC swap headers for 4th gens.I'll have to spend some time looking for them though.
I'd be worried about the rear end in that with a 454 it's not the strongest
Old Oct 6, 2012 | 01:33 PM
Well where the start is the camaro header fits perfectly it doesnt rub or anything but on the other side it hits on the frame not letting it line up on the motor so i would like to know if i can either heat up and bang one of the tubes a lil so it can fit or is there another way that it can be made to go around the frame and connect on to the motor?
Old Oct 6, 2012 | 01:42 PM
What are they from?
I honestly dont know what brand they are.Most likely they are stock camaro headers. My friend picked them up at a swap meet and he isnt using them any more so i thought i would give them a shot
Old Oct 6, 2012 | 01:45 PM
Well like i said in my replay i got the passenger side where the start is to fit right in perfectly i mean i rubs on the start but ill either and header wrap or and plate to cover the start but most likely to but a smaller starter.(sorry im new to this im getting use to replaying and stuff )
Old Oct 6, 2012 | 01:46 PM
I have another rear that im building up little by little its a 8inch rear out of a cutlass olds 442 80's style and im either planing to put 3.73 or 4.11's
Old Jan 4, 2013 | 08:27 AM
DixieMonteCarloDepot's Avatar
The part number for the big block headers are hooker 2241, You have to use solid motor mounts or trim the factory one on the driver side. A short oil filter and you may have to move brake lines, You can find them used but usually not incredibly cheap another option is the hooker 2245 which are first gen headers but you need to make a decent amount of modification to the headers for them to work as well as solid mounts and a remote oil filter.
Any other questions Shoot me a pm.
Rob@Dixiemontecarlodepot
cstyles
Mar 10, 2012 08:45 AM
Kracktheskye
Feb 5, 2011 02:55 PM
daisy9398
Jul 11, 2010 09:03 PM
85mightycarlo
Apr 25, 2010 06:53 PM
85mightycarlo
Apr 18, 2010 09:39 AM
