77 Monte Brake Booster Options
Old Jun 3, 2013 | 10:10 AM
77MC's Avatar
Default 77 Monte Brake Booster Options
I've recently converted to a Big Block in my 77 MC. I'm having trouble with valve cover to Brake Booster clearance. Are there any after market brake boosters that are at least 1 inch smaller in diameter that will work?
Old Jun 3, 2013 | 11:56 AM
Welcome to the Forum...
Depending on where you live...You can either check at your local Auto Scrap yard and see if they would know.... Or contact a local Chevrolet dealer that may be able to let you know whats interchangeable with your Model and Year.
What motor was in it? and what motor are you putting in it?
Old Jun 3, 2013 | 01:18 PM
77MC's Avatar
350 Small Block (ZZ4) removed
505 Custom Built Big Block with large valve covers.
The valve covers clear by about an inch but there no room for the 2" breather that has to go there. I'm hoping there's a 9" Dual diaphragm setup that fits.
Old Jun 4, 2013 | 06:28 AM
03SSLE's Avatar
Small block equipped vehicles use an 11" diameter booster and big block vehicles use a 9" diameter booster. You'll need to replace the booster in order to gain clearance for the valve cover.
Old Jun 4, 2013 | 06:33 AM
Thanks Mike!
Old Jun 4, 2013 | 12:26 PM
77MC's Avatar
Thanks guys. I did a little research and found there were 2 types of boosters used. The 11" is a Delco unit (which I have) and the 9" Bendix unit (which I am ordering). This should work, I'll keep everyone posted in case someone else gets into the same situation.
Old Jun 4, 2013 | 12:46 PM
Your very welcome.
With members Like Mike (03SSLE) That are knowledgeable and willing to share information...is what makes this Forum the Best on the Planet!
Old Aug 1, 2013 | 07:44 PM
DIGGMAN's Avatar
Tru DAT!
mike00
Aug 5, 2014 11:05 AM
rlj4214
Sep 3, 2011 08:16 PM
qzack1
Aug 28, 2011 12:50 PM
heinzp87
Nov 9, 2010 03:16 PM
loudNproudSS
Apr 24, 2008 06:54 PM
