5th gen trunk seal/weatherstripping
Old Apr 20, 2014 | 10:21 AM
3vom's Avatar
Default 5th gen trunk seal/weatherstripping
Anyone know if any newer model monte trunk seal will fit a 99 ls? It seems they've discontinued the gm part, and I can't find it anywhere online. Trunk is leaking pretty bad, and I know it's coming from the trunk seal. Not sure how as the weatherstripping doesn't look cracked or damaged.
Old Apr 20, 2014 | 10:25 AM
Any/All 5th Gens will fit...
1995 -1999
I would recommend going to a Junk yard/pull apart for a replacement.
I would also check for holes in and around the rear strut body mounts for holes/worn seals/rust.
Old Apr 20, 2014 | 11:24 AM
3vom's Avatar
That's what I was considering, thanks for the tip. They only charge $3 per seal, so I'll probably take 4 or 5 and hope one of them is good. The rear strut body mounts and seals look good, I used a hose and had my wife spray the trunk and could see it coming from the trunk seal from the inside. Should I treat replacement seals with anything before applying new adhesive?
Old Apr 20, 2014 | 11:28 AM
I haven't treated mine in 14 yrs...
Just a light cleaning (nothing harsh)...with soap and water..when I'm detailing it...
Just be sure you seat the seals properly... you could possibly use a very light coat of silicone or lithium grease...anything non petroleum based..
Old Apr 20, 2014 | 12:52 PM
3vom's Avatar
One last question, will any 2nd gen years lumina weatherstripping work on the trunk as well?
Old Apr 20, 2014 | 05:14 PM
You may want to check the actual flange the weather stripping is attached to. Perhaps it's bent and that's allowing water in (my mom had a Corsica once that did that).
Flash
Sep 26, 2013 11:02 AM
michelob
Jul 16, 2013 08:54 PM
montecarloLS350
Aug 5, 2011 11:56 AM
ohbob
May 21, 2010 07:59 AM
mickey
Jan 22, 2007 05:52 AM
