2008 MC SS Replacement battery
Old Sep 21, 2010 | 07:59 PM
kart74's Avatar
Default 2008 MC SS Replacement battery
I am hoping someone can help me. My monte carlo won't start just clicks. Tried to get a new battery and they said they had to order it??? How can this be? I know they are hard to get out but there isn't a special battery needed is there? Please let me know so I don't get sucked in and spend money not necessary.
Thank you
Old Sep 21, 2010 | 08:51 PM
MillerMonteSS's Avatar
2010 Monte Of The Year
I thought 2007 was the last year for the monte... Well, the battery is a very tight fit in the 2006 model and the location of the terminals makes it a little hard to squeeze any battery in there. Most autoparts stores won't do it. I ended up spending about $75 at autozone for mine. Don't let them sucker you into getting the $200 optima. They are good batteries, but you just need a stock replacement. Also, check with a local dealer. They will have the battery (at least for an '07) in stock. Good luck.
Old Sep 21, 2010 | 09:26 PM
seawolf18's Avatar
Any name brand battery will do. I, however, stay away from interstate batteries. I have had nothing but problems with them over the last few years.
Old Sep 22, 2010 | 01:05 PM
sportz's Avatar
Maybe the place you talked to didn't have the proper size of battery that works for your car. I would call around to a store that has them in stock. Like people said, it's just a battery. Nothing special. You just have to get the proper group size for your vehicle.
Here is a listing that may help? http://www.gglotus.org/ggtech/batter...y-bci-size.htm
Old Sep 22, 2010 | 07:52 PM
LuSe4's Avatar
Just curious, OP. Did you tell them it was for a 2008 Monte carlo? Maybe that is the problem.
Old Sep 24, 2010 | 01:12 PM
RickAKATed10's Avatar
Photobucket
lol...
Old Sep 24, 2010 | 01:50 PM
TheMonteMan's Avatar
the optima i got wasnt 200 and it fits alot better i believe its the 35 red top. removal is a pain, but removing the cover and the top of the fuse block makes it easier. the optima is also smaller so it squeezes in easier. and yeah 07 is the last year so that might have been your problem getting the battery. my autozone didnt have the red top inn stock only the yellow top that was more expensive, but it only took them a day to get it in.
cnogood
Sep 20, 2014 04:16 PM
70monte1
Jun 14, 2012 05:12 AM
DCfla
Aug 20, 2009 01:26 AM
stkks
Aug 15, 2008 07:51 AM
thorspower
Aug 26, 2007 01:37 PM
