2007 Monte Haynes Manual Question?
Old 12-13-2007, 05:57 PM
Twisted_Metal's Avatar
5 Year Member1 Year Member
Default RE: 2007 Monte Haynes Manual Question?
I purchased my rotors today from ACDELCO they cost me about $100 for 2 ...[:@] I guess I'll fix it this weekend ....
Old 12-13-2007, 06:17 PM
GrandPaDave's Avatar
ORIGINAL: Twisted_Metal
That's what I thought, but it's all one piece .... I need a 20-25mm socket and some leverage to move that nut ...
Autozone will rent the tool for free.
Old 12-13-2007, 09:23 PM
Yea I'm going to go do that ha! thanks
Old 12-14-2007, 07:51 AM
The center nut is an axle nut. It holds the axle to the hub you do not need to take it loose as alltak said. Take out the torx screw like 2000LS said, then use a softface hammer (Just in case you miss and hit a wheel stud, less chance of damage) and hit it a few times between the wheel studs that should free it up. Rust and road grime build up between the rotor and the wheel brearing making it look like it might be one piece and holding it together. A few good well placed raps with a hammer will do what you need it to do. The torx screw does not need to go back on unless you want to, it is put there to hold the rotor in place on the assembly line till the wheels go on.
When you put the wheels on it is extremely important to cross torque them to 100 lb-ft with a quality torque wrench. Improper installation on wheel/tires are a huge reason for a lot of rotor warpage front and rear.
Old 12-15-2007, 05:34 PM
Job Well Done! (Patting self on back)
New vs. Old
New vs. Old
Finished Job Left Front
Right Front Rotor Removed
Finished Job Right Front
They smoked a little after I drove awhile and people kept telling me my car was overheating and I just nodded and drove faster ....
Old 12-17-2007, 11:29 PM
Sure you aren't just feeling the Anti-lock Brakes kinkin'-in!
That car looks fast sitting still!
Old 09-27-2008, 12:41 PM
So did this fix your pulsing problem?
Old 09-27-2008, 02:12 PM
just buy the service manual for the 2006 Monte... same exact car/parts... probably why they don't have a separate one just for 07's...
jjsj10
05-31-2008 06:55 PM
bigbirm
03-27-2008 02:10 PM
jay26
12-20-2007 01:35 PM
Quick Reply: 2007 Monte Haynes Manual Question?
