2007 Monte Haynes Manual Question?
Does anyone have the Haynes Manual for the 2007 Monte Carlo V6 3.5L. I want to remove my front rotors and have them inspected for warping and I want to replace my front brakes, and do a oil change tomorrow. I wanted to see if I could have a diagram of what to expect. I've done brakes before on two other cars one a Mercury Station Wagon, and the other a Mazda 626LX and oil change, but I want to do it by the book with my new car.
RE: 2007 Monte Haynes Manual Question?
[:@] Well I almost had the rotars off, but then I noticed this isn't like a Ford..[:'(]
Damn, if I would of known the rotars were fastened to the axle I would of never took anything apart ...
I think I need a 25mm Socket to remove the center piece just to remove the rotar. I don't recall having to do this on my Ford wagon. I need a manual ...
I would hate to pay the dealer $45 for finding the problem and another $450 for parts and labor just to turn a frikin' rotar or replace it ... why are cars so difficult ...
Anyhow I'm still puzzled as to why my car pulsates at speeds over 80mph when I apply the brakes to slow down, but doesn't do so at slower speeds. Could the rotars be warped to a small degree where I isn't affecting the brake pads? Or is it just a heat issue with these cars and these type rotars?
This car was a used rental car with 15,000 miles on the O/D when purchased ...
The big nut in the center has to go before the rotar will free up? Ford is a little different where as the nut thingy stays on the car while the rotar moves freely .... well atleast that's how i remember when I had to have my Mercury Rotar replaced after a score from worn
brakes ..
The brakes look good (the same for the other side too no problems) why is my car pulsating when I brake?
brakes ..
why check for warping? either you have a brake pulsation or you dont... if you have a brake pulsation and a shimmy in the steering wheel only when braking, then the front rotors are warped
btw, you would need a dail indicator to check lateral run out. and a brake micrometer to check thickness variation
i'm not positive on the size, but think that big nut that you do not need to take off is going to be a 34 or 36mm
i'm guessing whats stopping you is that small black torx head bolt that holds the rotor against the hub
