7th Gen ('06-'07): 2006 no crank
Old Dec 3, 2018 | 10:45 PM
nrshotgun's Avatar
Default 2006 no crank
I have a 2006 monte carlo and the engine will not crank. I do have an engine light on but codes doesn't pertain to the no start. I had to install a manual starter switch in order to start the vehicle. Any help will be appreciated
Old Dec 4, 2018 | 07:29 AM
Jeffs02rwdSS's Avatar
Not sure if the generation 7 is the same as gen 6 . On gen 6 the fuse box under the hood has a crank or start relay . Other things it could be is the BCM or the ignition switch , I would think if the BCM was bad the security would kick on and the car would shut down . Hopefully others will have some ideas for you . Good luck
Yager Krenz
Nov 21, 2019 12:39 AM
doramold
May 31, 2016 01:50 PM
Dylan Farmer
May 24, 2015 09:08 AM
mrstaypuft1181
Jan 10, 2012 06:34 PM
lostcausenjtown
Jan 8, 2011 12:27 AM
