6th Gen ('00-'05): 2002 Monte Carlo SS wont crank intermittently
Old Nov 16, 2019 | 09:25 PM
Yager Krenz's Avatar
Default 2002 Monte Carlo SS wont crank intermittently
New user here, got a 2002 Monte Carlo SS with the 3.8L in it, intermittently wont start (starts fine twice then the 3rd time it won't) i try all the bypass tricks, unhook the battery and re-hook it on, attempt to start it in neutral, I only have 6 Volts going to the starter field exciter when it wont start, pulled the ignition switch, cleaned it out, replaced the ignition cylinder, but every 3rd start it won't crank or anything, lights come on and all, need some help on what else i can try.
Old Nov 17, 2019 | 07:06 AM
Jeffs02rwdSS's Avatar
Sounds like it might be a BCM security issue . The ignition switch sends power to the BCM and after it confirms all systems are good the BCM sends a ground to activate the starter relay which then energizes the starter. I guessing the wire your testing is the one going to the BCM . When it does start is that the same voltage ? Good luck
Old Nov 17, 2019 | 11:26 AM
I hooked up a code reader and im getting A U1016, related to the PCM, could that be the problem?
Old Nov 18, 2019 | 06:49 AM
The code is indicating it is loosing signal. If you just replaced the ignition switch perhaps it's a bad one , usually how things work out for me . Good luck
Old Nov 21, 2019 | 12:39 AM
claydoh's Avatar
try another battery, I had similar issue before turned out the battery, which was not very old had a bad cell in it !!?
NYGiantsfan
Jan 5, 2016 06:14 AM
Dubstepticon
Aug 19, 2015 08:00 PM
Dylan Farmer
May 24, 2015 09:08 AM
dbryant1928
Nov 29, 2011 11:53 PM
glewisr
Dec 15, 2010 11:02 PM
