2004 Intimidater Sunroof problem
Old Aug 26, 2009 | 11:47 AM
craig229's Avatar
Default 2004 Intimidater Sunroof problem
My sunroof will open fine , but when I go to close it I hold the button but the roof stops and I have to let go of the button and push it again. I have to do this like 10 times before it is all the way closed.Any suggestions.Thanks
Old Aug 27, 2009 | 02:36 AM
vincenti's Avatar
clean the contacts on the switch or replace it altogether.
Old Aug 27, 2009 | 01:45 PM
desertstars's Avatar
Have a friend close it while you watch from above. If it usually or always stops at the same point, you may well have a loose, misaligned track.
Adjust.
Old Aug 27, 2009 | 06:15 PM
espo83's Avatar
I agree with desertstars and vincenti check the contacts on the switch. and check to see if the sun roof track is misaligned also see if the track is greased.
Old Aug 27, 2009 | 11:12 PM
Enzo354's Avatar
STILL SLOW
Mine stopped alot, almost seemed like it was out of power. Put a bunch of some white grease on it I picked up and it closes way easier.
Old Aug 27, 2009 | 11:24 PM
Teacher's Avatar
Mine did that a few times when I left it open over night and it was cold out.
Old Aug 28, 2009 | 08:10 AM
Mine does that... oh wait. I don't have one
Hopefully some of the posts of other members have helped you? Did you get it working good?
Old Aug 28, 2009 | 06:57 PM
espo83's Avatar
the grease that enzo 354 is talking about is white lithium grease.
ladyvyxen
Jan 14, 2013 08:28 AM
victoryrc
Aug 16, 2008 02:16 PM
Fireman399
Jun 30, 2008 04:48 PM
kutch720
Oct 9, 2007 10:50 PM
ckerdflag
Jun 1, 2007 09:59 AM
