2003 LS Bumper the same as an SS??
Old Mar 8, 2007 | 04:56 PM
IAHKAT's Avatar
Default 2003 LS Bumper the same as an SS??
Is the 2003 LS bumper the same as the SS?
Old Mar 8, 2007 | 04:58 PM
wiz kidd's Avatar
Default RE: 2003 LS Bumper the same as an SS??
the front one??
well..both of them are...yes...you just have to cut the wholes in for the body kit to go through...all the little tabs, its actually the only one gm sells now...you have to cut the holes in it no matter what now...very easy job with a dremmel though...
and the fog light pieces you just have to unscrew the little plastic cover out of the way
so short answer yes...it will work...
Old Mar 8, 2007 | 05:07 PM
IAHKAT's Avatar
It's the rear bumper, the total to fix my car is $1000 but I noticed after I left they have my car down as a LS not an SS. Wanted to make sure the two cross fit..
Old Mar 8, 2007 | 07:49 PM
mickey's Avatar
ok what happend to your car?
i supose my box of stuff was in the trunk still also LOL
you cant keep putting it off by wreking your car.
Old Mar 8, 2007 | 07:57 PM
IAHKAT's Avatar
https://montecarloforum.com/m_29299/tm.htm
See this link for pics... I got rear ended.. Quote is $1000, but looking at the break down I did not see the tail light...
Your box of stuff is on it's way outta here. But once again, it survived... (The box that is)
Old Mar 9, 2007 | 10:19 AM
wiz kidd's Avatar
yah...rear bumber is same...just need to cut holes in it for the body kit to slide into
you can always check on ebay for this bumper ....sometimes they're on there really really cheap...
unfortunately from what i can see nobody other than gm is making the rear bumper...well in canada anyway...so check ebay and you can get them really cheap sometimes
but if its going through insurance just let the body shop do it and get it all through gm in this case...unfortunately its not made aftermarket..because they fit just as good as factory parts 99% of the time
Old Mar 9, 2007 | 07:02 PM
Donutboy97's Avatar
Monte Of The Month - April 2010 & Sep
ORIGINAL: wiz kidd
Wiz Kidd, he doesn't have the HSAP, so nothing has to be cut. The SS and the LS have the same bumper.
iMSeRiOuS
Mar 25, 2011 06:07 PM
monte003
Feb 9, 2011 06:56 AM
03SSChevyFun
Dec 23, 2010 08:51 AM
SS2001
Feb 27, 2009 05:25 AM
monte84
Jul 12, 2006 12:18 AM
