Intake Gasket Part #'s
Old Feb 25, 2007 | 04:06 PM
revelated's Avatar
Default Intake Gasket Part #'s
Hey everyone thanks for reading this message! I have a 1996 Monte Carlo with the usual intake leaking into the oil. I know that this has probably been asked before, but I was wondering which Fel-Pro part # I need to fix this problem. My VIN says "M" for the engine code.....I have the 3.1 V6. I phoned the local parts store and they show 4 different part numbers for 4 different designs......the GM dealer says I have "rolling rockers", I'm sorry if I said that wrong just I am not a mechanic If I have it right will the Fel-Pro part # MS98004T work to fix this problem? Or do I need a different part #?
Thanks again for your help!!
Old Feb 26, 2007 | 10:33 AM
wiz kidd's Avatar
Default RE: Intake Gasket Part #'s
yup, MS98004T and dont pay over 100 bucks for it...dont get ripped off on this...i'm in canada and i sell this for around 100 bucks...and if your in the states you should definetly be cheaper
Old Mar 9, 2007 | 08:27 PM
Bml97MC's Avatar
speaking of intake gaskets. VIP said, when i went in for a compression test that i should replace my Intake gasket, im like what the? the car runs finenothings leaking to my knowleged. nothing wrong with my compression by the way.
but i was wonderinghow much it wold be to get replaced? 3.1 L v6. and labor included?
Old Mar 10, 2007 | 10:22 AM
wiz kidd's Avatar
you probably dont need to have it changed..he's just suggesting it before you do HAVE to have it done...because sooner or later you will...
New2MonteNY
Apr 25, 2017 01:59 PM
PsuBrock
Feb 13, 2008 12:40 PM
SSDriver8
Feb 14, 2007 03:20 PM
monteriderLS
Nov 11, 2006 10:26 AM
agentk006
Jan 6, 2006 04:37 PM
