2003 drive wheels locked up
I will pre-apologize it has been a long night.
I am pretty sure it is the transmission, but it is odd. And hoping it might be something cheaper to fix.
The drive wheels are locked up, but you can still change gears, and if you hit the accelerator in Park/neutral no engine resistance in any drive gear engine bogs down. The car will not free roll in neutral. The brakes seem the be working correctly. I can pump them to build pressure and hold it after I let them go they act normal. Anyone had a similar problem or have any suggestions
thank you
thank you
They maybe able to rebuild it easier than to try an hunt one down and put it in and it may not be any good either.
6th Gen ('00-'05): How do I Fix my A/C ?
Kooni Holmes
May 14, 2016 11:00 PM
