Won't start
Old Nov 10, 2010 | 08:43 PM
glewisr's Avatar
Default Won't start
98 monte carlo LS, turn the switch on but won't start, replace the ignition/starter switch, still nothing. Can use a screw driver on the starter soleniod and it will start and run for about 5 seconds, then shuted off. Will start right back up but again for 5 seconds
Old Nov 11, 2010 | 12:54 AM
nitehawkjcb's Avatar
Will it crank? Just not turn over?
Old Nov 11, 2010 | 06:42 AM
glewisr's Avatar
You can jump the starter soleniod with an screw driver and it wil crank and run for about 5 sec.
Old Nov 11, 2010 | 08:30 AM
glewisr's Avatar
Try to start it w/key, nothing (won't turn over). If you use a screw driver, it will start but only run about 5 sec. then stop (it will start back up but only for 5 sec.)
Old Nov 11, 2010 | 09:21 AM
glewisr's Avatar
When you 1st turn the ignition switch, the pump will whine for about 2 sec.
Could it be something in the pmc?
Old Nov 11, 2010 | 12:03 PM
glewisr's Avatar
Had a friend scan it and got a thief code "P1629 Theft Deterrent System - Cranking Signal"
does anyone had any ideal what I need to do?
Old Nov 12, 2010 | 11:58 AM
labnjab's Avatar
Did you run the security relearn after replacing the ignition switch? If not I would do that 1st.
Here is a link to the relearn procedure https://montecarloforum.com/forum/fwd-tech-guides-95-07-62/security-re-learn-procedure-8598/
Old Nov 12, 2010 | 01:29 PM
x2 on the security relearn. But your pump is supposed to whine...
Old Nov 12, 2010 | 10:34 PM
glewisr's Avatar
labnjab, thanks for the infor about relearning the secunity
will try that tomorrow
Old Nov 15, 2010 | 12:56 AM
glewisr's Avatar
Didn't work, but thank's anyway
