2001 Monte Carlo Vibration during hard acceleration
I just bought a 2001 Monte Carlo SS, and right now its suffering from the ABS/Trac. Control issue with the Hub. I noticed though that while accelerating, the whole car started to vibrate, and the faster I got the harder the vibration. I was told by the guy that if I fix the hubs it will correct this, but I am not so sure.... could anyone give me some pointers so I can possibly know what I should be looking for?
???? Replace the ABS sensor and the vibes go away? Something about that solution does not hit me right, unless he replaces the wheel bearing and sensor as a unit. Perhaps you need to check your wheel bearings. Jack up and test each tire one at a time. With the wheel up attempt to wiggle the tire left and right. Then push in the top and then the bottom, left right in out. Any slop and it could be wheel bearings, ball joints or control arms.
Also inspect your transmission and or motor mounts. Perhaps the bushings on one of them has failed and lets the whole assembly flex on acceleration.
If you have vibration under accleration and it goes away when you let off the throttle it is the cv joints. You can pull apart the axle and replace them, and buy new boots, and re grease them, but it is easier to just buy a new axle as you have to pull it out anyways, and you probably have a lot of miles on it already. It will shake the whole car when it is doing it, but probably won't start vibrating till your above 25 mph. Just went through this issue with my car
6th Gen ('00-'05): hesitation during acceleration
BrandonStebing
Sep 25, 2018 08:31 PM
shovelhead pete
Mar 31, 2012 11:26 PM
superrod29
Mar 8, 2012 10:15 PM
I appreciate any tips I can get.
