2001 Monte Carlo not starting
Old Apr 20, 2020 | 03:08 PM
Seggers97's Avatar
Default 2001 Monte Carlo not starting
Good battery, good starter. I put key in only lights that come on is check engine can’t turn anything else on can’t lock or unlock car without key
Old Apr 20, 2020 | 03:21 PM
Seggers97's Avatar
I also plug in scanner and it doesn’t connect to car
Old Apr 21, 2020 | 05:38 PM
Seggers97's Avatar
Accessories don’t turn on when key is turn only check engine light turns on
Old Apr 25, 2020 | 10:13 PM
xpage's Avatar
Sounds like BCM is bad.It controls the locks and many other functions
Old Apr 26, 2020 | 10:05 AM
Just because the lights are on, do not mean the battery is charged enough. I also know from experience, when the battery is low, the car can do "weird" things. A common one for mine was the back up lights would flash.
I would do two things:
1. - Make sure the security message is not displaying on the instrument panel. If so, the car may be dealing with a passlock/theftlock issue.
2. - Ensure the battery is properly charged. Check with a volt meter OR take it into a parts store and they can bench test it.
Also, keep in mind, keyless entry is controlled by a keyless receive (just in front of the dash, you have to remove the windsheild vent piece) and that works with the BCM. If you have low power, again, these cars can do weird stuff.
MonteCarloKZ
May 6, 2024 10:26 AM
highdefinition223
Feb 8, 2015 10:03 AM
kmassing
May 9, 2013 06:54 PM
j5atl
Oct 11, 2011 10:24 PM
Shandley
Nov 6, 2010 03:48 PM
