2001 MC ignition switch/lock cylinder replacement
Hi all, having ruled out the bcm as the source of my starting problems I'm focusing on the ignition switch. For those of you that have had this replaced to fix passlock/starting problems did you replace just the switch or did it require that the lock cylinder also be replaced?
Are there any brands of switches to avoid? I see the Dorman part is a lot less than others. I've used that brand for several things and they all worked fine.
Thanks!
Thanks!
6th Gen ('00-'05): Pass lock/ignition cylinder/BCM problems
dbaldwin
07-02-2014 12:32 AM
jeremyjlewis02
10-24-2011 01:28 AM
01, 2001, bad, carlo, cylinder, heat, ignition, lock, monte, montecarlo, montercarlo, replace, replacement, repolacment, switch
