2001 MC ignition switch/lock cylinder replacement
Old Sep 24, 2012 | 04:40 PM
jim1405's Avatar
Default 2001 MC ignition switch/lock cylinder replacement
Hi all, having ruled out the bcm as the source of my starting problems I'm focusing on the ignition switch. For those of you that have had this replaced to fix passlock/starting problems did you replace just the switch or did it require that the lock cylinder also be replaced?
Are there any brands of switches to avoid? I see the Dorman part is a lot less than others. I've used that brand for several things and they all worked fine.
Thanks!
dbaldwin
Jul 2, 2014 12:32 AM
Holly19
Nov 18, 2011 06:14 PM
jeremyjlewis02
Oct 24, 2011 01:28 AM
psson24
Feb 22, 2008 12:10 PM
greatness107
Feb 2, 2008 07:14 PM
