2000 Monte won't start after new ignition and cylinder
Hi Everyone,
I purchesed a 2000 Monte, and the key was not functioning properly from the day I bought it. Eventually you could just pull the key out no matter which position it was in. About a week ago the car stopped starting all together. i have lights radio, but won't crank. I replaced the lock cylinder and the ignition switch after i read all the post regarding that. After I replaced it i went throught the 10 min cycles with the security light flashing on the fourth try still nothing. The security light no longer blinks, but she still won't crank. Any help would be greatly appreciated.
I appreciate all the replies.
The door lock on the iside does work
the fuel pump kicks on with the first click of the key
I checked every fuse in all four fuse boxes
changed the relay from the passenger side to the driver side
Still Nothing.
Still Nothing.
6th Gen ('00-'05): monte carlo won't start immediately after installing new battery
bonzolead
02-26-2015 10:15 PM
monte2001carlo
01-12-2011 05:17 AM
