2000 Monte won't start after new ignition and cylinder
Old Nov 22, 2010 | 01:07 PM
dennis7711's Avatar
Default 2000 Monte won't start after new ignition and cylinder
Hi Everyone,
I purchesed a 2000 Monte, and the key was not functioning properly from the day I bought it. Eventually you could just pull the key out no matter which position it was in. About a week ago the car stopped starting all together. i have lights radio, but won't crank. I replaced the lock cylinder and the ignition switch after i read all the post regarding that. After I replaced it i went throught the 10 min cycles with the security light flashing on the fourth try still nothing. The security light no longer blinks, but she still won't crank. Any help would be greatly appreciated.
Old Nov 22, 2010 | 11:04 PM
lucian*91's Avatar
key fob work?
Old Nov 23, 2010 | 01:21 PM
dennis7711's Avatar
didn't come with a key fob
Old Nov 23, 2010 | 01:28 PM
You may have to take it to a dealership so they can use the Tech-II scanner to program the key to the security system
Old Nov 24, 2010 | 12:42 AM
lucian*91's Avatar
does the power door lock switch on the inside work?
can you hear the fuel pump go when you turn the key one or two clicks?
Old Nov 26, 2010 | 10:33 PM
Justin Knight's Avatar
check fuses for ignition and swap the RAP relay with a less important one and see if it starts. the RAP relay is in the drivers side fuse panel.
Old Nov 27, 2010 | 03:48 PM
dennis7711's Avatar
I appreciate all the replies.
The door lock on the iside does work
the fuel pump kicks on with the first click of the key
I checked every fuse in all four fuse boxes
changed the relay from the passenger side to the driver side
Still Nothing.
Old Nov 27, 2010 | 07:57 PM
lucian*91's Avatar
ok, so the security is out of the question, i would deffinatly check the starter then. if you know whick two post on the starter to jump with a screw driver you could see if it will turn over and crank the engine
bonzolead
Feb 26, 2015 10:15 PM
JayBay
Jul 8, 2013 07:31 PM
monte2001carlo
Jan 12, 2011 05:17 AM
jeff2425
Dec 10, 2009 10:50 AM
jeff2425
Dec 9, 2009 07:05 AM
