2000 Monte LS Cranks but won't start
Old Apr 10, 2011 | 11:39 PM
hlee's Avatar
Exclamation 2000 Monte LS Cranks but won't start ( PLEASE HELP)
I have a 2000 monte carlo ls. Frequently but randomly it won't start. Most times when I turn the key to the on position I notice the fuel guage is on E regardless of how much gas is actually in the tank. Sometimes the gas gauge works. The security and battery light blink back a forth. When I turn the key it turns over but won't start. Sometimes it will kinda start (for a split second) but just dies. If I leave the key in the on position and don't try to start it the dashboard LCD gear display go's away (the LCD mileage display stays). I recently had the key and ignition replaced because that was also acting up (where the car wouldn't turn over at all, accompanied by the security light). I could really use some help here. I want to narrow down the possibilities of what is wrong. I've been told that it is a possible bcm issue.
Thanks ahead of time for any help.
Old Apr 11, 2011 | 06:51 AM
Sorry to read about your problems. Use our search engine & explore for the answers until one of our expert tech member's can assist...Wish you good luck on resolving your problem with your Monte Carlo.
Old Oct 8, 2012 | 02:29 PM
kgerowsun's Avatar
Hi, I am having the same problem. What did you come up with?
Old Oct 8, 2012 | 10:25 PM
@kgerowsun - This thread is over a year old and the original poster only posted once (and it was to start this thread). I advise starting a fresh thread about your situation.
Old Sep 28, 2019 | 11:26 AM
Old03SSDriver's Avatar
Default What fixed it?
What fixed it.
Emmanuel Warrick
Jan 20, 2020 07:14 AM
2000 Monte
Aug 8, 2014 01:25 PM
2000 Monte
Jul 17, 2014 12:52 PM
r8erpops
Oct 9, 2012 01:53 PM
Beckysue
Oct 21, 2011 02:08 PM
