2000 monte carlo wont start...plz help
Old Jul 24, 2012 | 07:06 PM
modollas's Avatar
Default 2000 monte carlo wont start...plz help
hi,
I bought a 2000 monte carlo like a month ago everything wuz fine untill the other day when I tried to crank the car and it wouldnt start (it cranks over it just doesnt catch) well I thoght it wuz the fuel pump I tried sum starting fluid in the throttle body still nothing...what could it be?? AM very angry because I didnt even get to enjoy my car now it wont even start plz help
Old Jul 24, 2012 | 09:04 PM
Could be a lot of things going on. Do you know if:
- You have any active check engine codes?
- Are you getting spark?
Without more info, could be:
- Bad ICM (Ignition Control Module), easy to remove, most parts stores can bench test it
- Failed fuel pump
- Hopefully, you have gas in the car and no fuel line leaks (I know it sounds silly, but sometimes the easy things are overlooked OR you are believing a bad fuel gauge)
- Bad sensor or sensor wiring
If you are able to find if there are active codes, those help narrow things down.
schoentges16
Feb 27, 2021 06:43 AM
2000montecarlo
Jan 21, 2012 07:37 PM
dbryant1928
Dec 1, 2011 07:09 AM
00monteSUPRSPRT
Jan 7, 2011 03:18 PM
01MCSS52
Sep 23, 2009 10:30 AM
