Car wont start help plz!!!
Old Sep 21, 2009 | 09:27 PM
01MCSS52's Avatar
From: <embed width="440" height="420" type="application/x-shockwave-flash" src="http://v5.tinypic.com/play
Default Car wont start help plz!!!
ok i have a 01 mcSS and for some reason, when i put the key in the ignition, nothing on the dashboard lights up and the car will not turn on at all, to get it to start, i had to unhook the middle plug from the BCM and put it back in, and the dash will come on and it will start but not for long, if i leave it off for a while, wont start again, i was told it was the dash[instrument cluster] but a while ago i had a aftermarket alarm installed and it had auto start on it( dumb idea) and for a while if my car was on, it would always say security but i never knew why, so did the auto start mess with my security system even tho i've had the alarm taken out ever since it started to not start?
Old Sep 22, 2009 | 08:19 AM
If you see the security light when you try to start the car it's probably going to be a passlock issue. Which unfortunately the dealer is going to have to replace your system and make your new cylinder respond to your current keys.
Old Sep 22, 2009 | 08:26 AM
MAMONTE's Avatar
That aftermarket alarm sounds like the issue...I think it messed with your passlock, which like Chibi said...dealer!
A lot of the aftermarket alarms have their own engine imobilizers (spelling?) yet GM's Passlock is already an imobilizer, but better than anything aftermarket. I would guess the two combined made for a car that does not run...
My suggestion, get rid of the aftermarket alarm...or just use a very basic, alarm ONLY, with non of the extras....
Old Sep 22, 2009 | 11:57 PM
01MCSS52's Avatar
well the only time it says security is when i disconnect the bcm, then connect back, it will say that b4 i start the car, if i dont disconnect the bcm and just try to start it, nothing will happen, no dashboard lights, only thing i get is radio, and headlight, domelights etc. but nothing dealing with the dash and car starting, as if i had a killswitch installed, which i did when i had the aftermarket alarm, but the alarm is goin now, but ok, so its something dealing with the passlock sensor? what is the dealer going to have to do exactly? and does any1 know how much this will cost?
Old Sep 23, 2009 | 07:51 AM
Well if there's something wrong with your Passlock and BCM because of the aftermarket alarm... you could be looking at almost $800 in repairs...
Old Sep 23, 2009 | 08:18 AM
MAMONTE's Avatar
Get the alarm taken out BEFORE you go to the dealer...that COULD fix your problem...thsoe aftermarket kill switch things don't work so well when they mess up...
BUT, I am leaning toward the alarm needs to go, and on top of that, it screwed up your passlock system...
I have no idea about the price on that...but Chibi's estimate sounds like a good ballpark...
Old Sep 23, 2009 | 09:03 AM
White04monte's Avatar
yea its probably the alarm but i remember on my first car i had the same kind of probably but i only had a factory alarm anyway i thought it was the alarm and i would mess with it and sometimes it would work but i found out i just had a loose ground wire and i was just wiggling it inadvertently so its a long shot but might be worth checkin before you spend the money
Old Sep 23, 2009 | 10:18 AM
01MCSS52's Avatar
"MAMONTE" the alarm is out already i had it taken out soon as i started having the problem, but thatnks to every1 for the help, ill b giving the dealer a call, and b taking it there soon as i get some $ because i kno whatever it is, isn't going to be cheap lol
Old Sep 23, 2009 | 10:30 AM
MAMONTE's Avatar
Oh...I must have missed that part! LOL!
Then I guess dealer it is!
schoentges16
Feb 27, 2021 06:43 AM
BrandonStebing
Jul 25, 2014 11:03 AM
Knightwolf702
May 14, 2014 07:13 PM
modollas
Jul 24, 2012 09:04 PM
yd0502
14
Feb 23, 2007 05:22 PM
