1999 lumina rear disk calipers
Old Jun 25, 2006 | 07:07 PM
fastback4's Avatar
Default 1999 lumina rear disk calipers
my son replaced his rear calipers with rebuilds from autozone. problem is he can't figure out how the bolts hold the calipers onto the brackets. i looked at it yesterday and the calipers have 1 mounting hole that goes completely through the caliper for mounting but the other hole has a cap on the end. short of buying a repair book can anyone assist us please.....Regards.....Tom
Old Jun 25, 2006 | 07:51 PM
montejass's Avatar
Default RE: 1999 lumina rear disk calipers
Hello Tom,
Caliper's generally have two bolts that hold it to the caliper bracket. In general, they also should run through some sort of an protective rubber boot to keep all the junk out of the slide area of the bolt. If you have the means, post a picture of the cap you mentioned. Is the cap plastic?
simdog765
Jun 19, 2013 08:53 AM
THRobinson
Apr 11, 2012 07:53 AM
$400 Z34
Dec 22, 2011 10:07 PM
monte97
Mar 29, 2006 05:54 PM
