1998 MC with 3100 engine - basic maintenance questions
Old Sep 20, 2010 | 09:27 AM
Luke's Avatar
Default 1998 MC with 3100 engine - basic maintenance questions
Hello guys,
I wanted to do some work on my wife's MC and have couple of questions.
1. Cooling system - I wanted to overhaul cooling system. Car just hit 100k miles and lower hose is leaking - should I perform complete overhaul at this mileage or just take care of the leaking hose? If just the hose, would you recommend aftermarket parts or should I go OEM?
2. Anti lock light came up - I've read here on the forums that it is due to the speed sensor failing in the hub thus the hub needs to be replaced but I would appreciate if someone could share some more knowledge about this.
Is there a DIY knowledge base on this forum?
Thank you,
Lucas
Old Sep 20, 2010 | 10:35 AM
Sparky-88's Avatar
Lucas,
If the car is not having cooling issues and has been well maintained, I'd recommend just doing a thorough flushing of the system. Wouldn't hurt to take a peak inside the radiator to see if it has significant build-up of crud.
As for the hose, their all pretty much the same. See what your local auto parts store can supply.
Sorry, not much help on #2.
Old Sep 20, 2010 | 11:09 AM
labnjab's Avatar
You need to know the code for the abs light, it could be any number of things, bad wheel speed sensor, bad tone ring, faulty wiring, bad computer, the list goes on.
Old Sep 20, 2010 | 12:16 PM
Luke's Avatar
Thanks, would local autoparts store be able to read it or do I have to swing by the stealership?
Joe Bloggs
Dec 5, 2010 04:58 PM
RickCoMatic
Feb 14, 2008 10:10 AM
BeachBumMike
Nov 6, 2007 08:47 PM
cymbolkid
Nov 13, 2006 08:15 PM
SoCalSS
Jun 14, 2005 02:55 AM
