Basic Fog Lights Wiring Question.
Old Feb 13, 2008 | 10:10 PM
RickCoMatic's Avatar
Default Basic Fog Lights Wiring Question.
FedEx coughed-up the box they said they delivered yesterday; today! I have my Fog Lights Plug-in's and am getting ready to wire the Fog Lights very soon. I need to know which side of the Connector is Hot and which is Ground.
As you look at the Fog Light Plug in which is inserted into the back of the Bulb Holder ... one side is Solid and the other side is Slotted.
With the two wires of the Connector on the Left ... and, the Slot facing you (not the solid side) ... which of the two wires is Hot? (+12V)
The Upper one, above the slot, with the wires going in on the left ... or the Lower one?
Or, ... as long as I do them both the same way ... does it really matter?
Anybody got a wiring diagram? Or, happen to know?
Thanks a lot,
Old Feb 14, 2008 | 08:32 AM
Cowboy6622's Avatar
Default RE: Basic Fog Lights Wiring Question.
as long as you go the same way I wouldn't think it shoudl matter. if you have a test light, groudn it out on some metal and touch each side, the side that lights up, thats the hot side.
Old Feb 14, 2008 | 09:15 AM
04 Intimidator's Avatar
Thats right, you got the aftermarket ones. My OEMs I had for the Saturn had a dummy plug so you didn't need to worry about it.
Anyway, as far as I've seen, Cowboy is right it shouldn't matter but I would hook up both lights the same way.
Old Feb 14, 2008 | 10:10 AM
mad717's Avatar
Not about your lights, Rick, but if you want some of the members to photoshopdifferent spoilers for you, you should start a thread and ask for help. I'm sure you'll get lots of help.
guzzimane
Apr 27, 2014 10:02 AM
clancaster23
Dec 29, 2009 06:30 PM
RickCoMatic
Feb 15, 2008 08:44 PM
BeachBumMike
Nov 6, 2007 08:47 PM
SoCalSS
Jun 14, 2005 02:55 AM
