1995 Monte Carlo ls factory radio question
Old Sep 21, 2013 | 11:44 AM
firstcarlo95's Avatar
Default 1995 Monte Carlo ls factory radio question
I'm trying to install my amp and sub setup and I can't seem to find if there is a remote turn on out of the back of the factory radio. If there isn't Then no worries I'm just going to throw my aftermarket radio in it cause I know that has one. I would like to use the factory radio if possible for the reason it has it's own bass turn **** and my parents are hard asses about loud music so they could just turn down with the bass ****. Thank you I hope there is someone that can answer my question
Old Sep 21, 2013 | 02:31 PM
skylark65's Avatar
i've seen at least one factory headunit made to work with an amp and subwoofer, sounded really damn good too BUT i don't know how it was wired... but it is possible.
Old Sep 21, 2013 | 07:18 PM
tps221's Avatar
just do the aftermarket one. my sony headuint blows the tape deck one out the water. there were no sub outs on the tape deck radio i had
Old Sep 21, 2013 | 08:02 PM
I have a sub/amp hooked up to my factory radio. The signal for the amp comes from the rear speakers, just spliced into them. Remote wire, I just have it wired to a wire that's on with the key.
Old Nov 10, 2013 | 01:42 PM
yeah i just put my aftermarket head unit and amp in cause all the buttons kept falling off the dam factory radio. its pretty bangin now. i have only two 6x9's hooked up along with my 1000 watt pioneer 10 inch sub in a box tuned to 35 hertz powered by a 480 watt sony xplod amp so its not to much use on the sub.
guysnydr
Sep 18, 2013 07:43 PM
volkerc
Mar 31, 2013 05:17 AM
Gthirteen
Apr 3, 2011 06:25 AM
ralphtrent
FWD Tech Guides '95-'07
Nov 28, 2010 04:35 AM
rgant_19
Apr 10, 2008 11:32 PM
