06 Monte need help please
Old Apr 27, 2011 | 11:03 PM
06LTMonte's Avatar
Red face 06 Monte need help please
My 06 3.9L has the remote start and when I turn it on through that or just put heat or a/c on it makes a loud clicking noise for a few mins. And stops on its own after that....souns like a motor idk if it is a motor how much is it to replace?
Old Apr 27, 2011 | 11:20 PM
1998 z34's Avatar
try looking at the starter first it might not be shooting out the way its happend to me befor
Old Apr 27, 2011 | 11:47 PM
06LTMonte's Avatar
It also happens when driving the car...so can it still be that?
Old Apr 28, 2011 | 12:00 AM
I've never had that happen with my remote start etc, I wonder if it could be a bad actuator motor type issue between heat/ac with your car, trying to get the climate controlled to the correct setting when remote starting? Does it happen when you don't use the remote start?
Old Apr 28, 2011 | 12:04 AM
1998 z34's Avatar
o no for get the starter sry. is it only when the heat or a/c is on if so could be that motor.
Old Apr 28, 2011 | 12:12 AM
06LTMonte's Avatar
No it has happened no matter how I turn on the car
Old Apr 28, 2011 | 12:46 AM
MillerMonteSS's Avatar
2010 Monte Of The Year
The actuator that switches between circulating air and fresh air can be damaged over time and will need to be replaced. Try switching between the two and it will make that noise. Good luck!
Old Apr 28, 2011 | 10:30 AM
06LTMonte's Avatar
It does it on either or no matter what
Old May 11, 2011 | 12:12 AM
04MCSC_06MCSS's Avatar
This also happened to my monte and the temp actuator on the driver side was replaced under warranty. Since then my fresh/recirc actuator part has done the same thing and no longer allows outside air - time to sue GM - any lawyers out there? there are 4 p.o.s. actuators on my car and 3 have destroyed themselves in 4 years. SEE thread on ticking also utube: YouTube - 06+ Impala AC tick fix vid.wmv
chevyONmine
Aug 1, 2023 07:33 AM
MCSS06
May 29, 2015 08:04 AM
LegaBone
Aug 20, 2012 03:30 PM
blackmonte781
Oct 3, 2011 01:38 PM
rmase182ls
Feb 28, 2011 03:57 PM
