03 monte carlo fog lights
Old Jul 7, 2013 | 01:38 PM
Blake Farrar's Avatar
Default 03 monte carlo fog lights
i have recently put after market fog lights in my Monte Carlo ls. the fogs now look like stock fog lights and i want them to be hid. but i don't think i can change the bulb in the after market fog light. so i was thinking of getting stock lights and wiring them up with the after market wires that i already have installed. I was wondering if i could do this or would i have to buy all factory stuff to go hid. Any help would really be appreciated.
Old Jul 7, 2013 | 08:35 PM
RocknSS04's Avatar
From what I've been told, HID's will burn up factory fog lights. I'm looking at these and converting them to HID's:
Universal Ready Projector Glass Lens for Car H3 HID Xenon Bixenon Bulb Fog Light | eBay
Glass and metal construction, not all plastic like the factory stuff. And I just bought a replacement for $50 for one.
Old Jul 8, 2013 | 02:43 PM
how are you planning on converting them? and let me know how it works out man i might try it.
Old Jul 19, 2013 | 04:36 PM
New2MonteNY's Avatar
HIDs will NOT burn up the factory fog lights. I've had 35W 6000k in my '01 since last March and have never had a problem. I wouldn't use the 55W HID kits...then you might have a problem burning them up.
Old Jul 19, 2013 | 06:08 PM
JC Colon's Avatar
The Keyword here is Kit. If you just get the H.I.D. lights they can/will burn out you harness due to higher current, aka more heat. The full kit should have everything you need to properly install them, worry free!
Old Jul 20, 2013 | 05:12 PM
seen03's Avatar
Most aftermarket lights (fog/drivinglights), use a H3 bulb, and ARR replaceable.
To replace the bulb, u usually have to disassemble the light 'housing'to access the bulb.
Old Sep 7, 2013 | 05:05 PM
sdowney's Avatar
Old Sep 8, 2013 | 07:53 PM
Originally Posted by sdowney
There are OEM replica's of the fog light enclosure on amazon. I used them and they fit perfectly.
Link:
Amazon.com: Chevy Monte Carlo Replacement Fog Light Assembly - 1-Pair: Automotive
Those are the ones that I bought..but I bought them on Ebay for $100 for both of them..
Old Sep 9, 2013 | 04:19 AM
i have some 55watt fogs i bought off ebay for 70 and they work perfect. I was just wondering how i could get some 10k fogs to match my headlights.
Old Sep 10, 2013 | 06:02 PM
Blake Farrar, you're running 55 watt HID's in your fogs? Those 10k have to be really blue...If u want your fogs to match you might have to get 12k because the 55 Watt is going to take some of the blue away. I always run 6k in my 3 cars..
rg9johns
Jan 2, 2022 05:51 PM
chevykid404
Jun 3, 2015 06:46 PM
rg9johns
Aug 22, 2014 10:46 PM
guzzimane
Apr 27, 2014 10:02 AM
dc1
Nov 9, 2013 01:48 AM
