BCM issues???
Old Sep 10, 2013 | 09:16 PM
5STAR's Avatar
Default BCM issues???
I have a 2005 SS SC MC and I'm having a couple issues...First is I notice sometimes driving at night that the headlights will turn off by themselves. They will turn off and then turn back on within a sec or two. I notice they also act up when I switch from lows to highs. I do know that the when I pull the turn signal arm back to activate the highs it doesn't seem to make a good enough of a click type feeling. So I know that could possibly be an issue (something that I'm going to change out soon) Also when the headlights go out/turn off that the radio stops playing/no sound and then comes back on.
New to the whole MC thing so I'm trying to learn and I was reading about the possibilities of a BCM issue
The second issue is When at WOT is has a hesitation/surge and check engine light flashes then goes out. I've changed the plugs and I'm getting ready to change wires next to see if the miss/hesitation/surge goes away. The one thing that bothers me is while at WOT is rolls like a yellowish/white smoke out the tailpipes. Doesn't appear to be loosing any coolant anywhere, I'm leaning towards it being a lean issue at WOT. I know coil packs are good, so I'll change plug wires and see.
There was only on hard set code and it was a random missfire. So really leaning towards plug wires ATM.
1stz51
Aug 18, 2019 03:18 PM
5Ringz
May 8, 2009 08:03 PM
dustybird3
Apr 1, 2009 11:57 AM
willie8701
Mar 30, 2008 08:46 PM
willie8701
Mar 28, 2008 10:18 AM
