1 mile from home and this happens
Old Feb 2, 2010 | 05:57 PM
mak330's Avatar
Default 1 mile from home and this happens
so i was driving home earlier and im 4 blocks from my house, then i get two idiot lights.
Service Traction Control
Service Brake Assist
So I called the dealer, and they said its most likely a wheel bearing or sensor, since they poped up at the same time. I feel shaking at around 40 mph, thought the wheels were off balance. The brakes still work.
if anyone has any insight id appreciate it.
Old Feb 2, 2010 | 06:31 PM
aussiek2000's Avatar
Yep, sounds like a hub.
Old Feb 2, 2010 | 09:13 PM
mak330's Avatar
ok im gettiing it checked tommorrow for codes. ive been doing some reading and this seems to be a common problem. from what i read it could be the brake fluid level is low. i thought it was low the other day but did not know how to check.
is this too low???
File Type: jpg
Old Feb 2, 2010 | 09:41 PM
now is the time to tell them to check for your recalls or service bulletins, let us know what they find! thanks
Old Feb 2, 2010 | 09:48 PM
mak330's Avatar
30,000 miles my breaking point
lol the funny thing is that i tried to describe these problems to the dealer while i had warrenty and they said were fine. dont get me wrong i got a lot of minor issues fixed but 2 months after its over i get all these problems.
steering knucle pops - deal said they replaced but problem persists 4 months later - i think they just greased
vibration at around 40-60 - w/o pushing the acelerator
traction light-------bad sensor/wheelbearing hub/wiring
abs light-----------
horrible ping coming from cat, i think its clogged and 2 months old
leaky transcooler line - should be recall / under powertrain warrenty
i think a leak in the power steering system - was low to the add mark - 06's got a recall
slow coolant leak - suspect water pump/ line
dash/defrost plastic on dash distorting
rust around front strut mounts
radio = static b4/system install
im sure ill find something new tommorow
next step sue the guy i bought it from
Old Feb 2, 2010 | 09:54 PM
holy f dude that sucks man!
Old Feb 2, 2010 | 10:04 PM
mak330's Avatar
yes i believe i got a lemon but damn. i already had to get these fixed
rear defrost
side mirror + switch
exhaust rusted through
stab links
iss
knuckle
im sure theres a few more
Old Feb 2, 2010 | 10:07 PM
SpinEm_90's Avatar
damnn man i'm sorry =[ that really bites! hope everything gets straightened out
Old Feb 2, 2010 | 10:09 PM
mak330's Avatar
thanks there goes the bank account and the tax refund
so long dual exhaust and ltz bumber
Old Feb 2, 2010 | 10:23 PM
SpinEm_90's Avatar
when did you buy the car? did you like inspect it and all before you bought it?
