Under Dash lights
Ok I am looking to change the lights under the dash and maybe buy a LED set up in my 06 Monte. Then wire them into those so that when I open the door they will turn on and turn off when I close the door. Ofcourse the exsisting lights that are there now wont turn on anymore. Well if anybody can help that would be great. and then when I install them and get them working right I will post a how to on the install and I will try to upload some images of it as well. Ok thanks again.
Hey there! So your looking at LEDs huh. Good choice they are easy to use and last. Are you looking to change just the floor lights or others as well? Here is a site that I go to... Www.vleds.com With these all you need to do is switch them out with your dome and under dash lights.
rg9johns
Aug 22, 2014 10:46 PM
01LS Goin Bad
Oct 28, 2011 12:48 AM
