Sub Capacitor
#32
i disagree. i think you should use a capacitor. i have 3 12" pioneer competion subs and alpine door speakers with 2 3"tweeters in a ported box with 2 2000 watz amps it rune through a capacitor but also 2 batteries. i think it helps if u are running alot through it, then its useful. if u dont think so run batteries
#33
first of all i play my music about 3/4 the way up most of the time that i drive. o think ppl that are having problems try to think they have a bigger system then they do. if your playing you head unit full go then maybe you should ajust you amps.
wow yall are nuts, as far as red tops go i dont have one, i just use the ac delco that came stock. i think i have a v maxx charge tank battery in the trunk. im running around 2000 rms watts "real watts", no b.s. it says i have 2000 watts on the front of the box watts, and mine runs fine. i have a 07 LT with a 125 amp alternator though so idk if that helps.
does anyone know how many amps the 00-05 alternator has??? if its smaller that might be your drawback, or possiblly the wiring job?
#35
#37
i run more than that through it all the treble come from the alpine door/panal speakers i put in and they use a good amount of that. i also put it in with an amp rack and red inglow lighthing in the box just for looks. also i figurered incase i ever wanna run other stuff off it or upgrade i can.
#40
read
http://forum.realmofexcursion.com/el...capacitor.html
do not get a cap its not a solution.
if your having dimming problems do the big 3 another bat or better alt. capacitors are not magic and actually store electricity inside them which is so inefficient ts ridiculous. car batterys dont actually store electricity. they store a chemical reaction. and when the chemical reaction is reversed it gives off electricity. so dont get a cap ever.
Robert-12-21
02-20-2013 10:42 PM
