6th Gen ('00-'05): Steering Wheel Button Installation HELP
Old Oct 17, 2012 | 12:20 AM
irace88's Avatar
Default Steering Wheel Button Installation HELP
Hey all!
I purchased a set of steering buttons a while back since mine have been chipped off, and now cruise has stopped working, which may be unrelated. However, I have had very little time for anything but classes and work recently, so I haven't had the chance to get them installed. I gave it a shot again today, but can't figure it out! The last thing I want to do is deploy an airbag or damage something on the interior of the wheel, so I am turning to you guys for help.
I have the entire columns and wiring harnesses. I simply need to know how to get the old column off and the new on, preferably without breaking anything
Thanks!
Old Oct 17, 2012 | 11:02 AM
Habbibie's Avatar
Ok i just did this two days ago.
1. Disconnect the negative battery terminal
2. On the left side fuse panel, if u open it you gotta look downwards of where the fuses are, there will be a thick wire with a yellow plug and has an Orange safety pin. Be careful not to break it,that will disable your airbag completely.
3. Behind the steering wheel cover there r 3 holes. Find them
If you look in those holes there is a star bit screws, dont remove them
4. Right next to those screws there is a hole and what looks like a wire fence link, use a powerful flashlight to see them better.
5. On those links you will have to use a flat head screw to push them inwards and then force it either left or right, work it somehow and eventually all three will cause the airbag to dismount, after that its all self explanatory.
7. To disconnect the horn wire (red wire in middle with a spring) push it in and twist to take off and on
After that every thing is right there in front of you
Old Oct 17, 2012 | 01:42 PM
Franks 03SS's Avatar
2011 Monte Of The Year
This is what you should see in the holes lol
Old Oct 17, 2012 | 02:58 PM
irace88's Avatar
First, thanks to both of you!
Habbibie, on #2 what do I do with that orange pin? I'm not by my car now nor will I be able to check it out for a while, but do I remove the pin or what?
Thanks again for the help!
Old Oct 17, 2012 | 08:46 PM
Habbibie's Avatar
Its a safety pin so the yellow connectors dont come apart by vibration, or unintentional foul play. You remove it using a small flat head and then you pull the yellow connectors apart.
And Frank thanks for the picture,
Old Mar 3, 2019 | 02:16 PM
gmjunkyard's Avatar
I just removed my airbag based on the information and photos provided in this thread. I took some close up images while I was doing it and put together this collage. I hope this will help explain it to someone who has never done it. Main thing I learned is to insert the flat blade screwdriver with the blade running parallel with the pins in the steering wheel. The pins are spring loaded. Remember to not yank on the airbag or it will rip out the connector to the horn button. Just turn the connector counterclockwise 90 degrees to remove it.
Old Mar 5, 2019 | 06:41 PM
SuperchargedMonte's Avatar
Thank you to everyone's input on this. I purchased new buttons a while back and was a little leary of this process but now I am ready!!
Old Sep 2, 2019 | 10:19 PM
Glen01SS's Avatar
This is a great write-up and the photos are perfect for explaining how to release the airbag - I used it to get buttons from a 2000 and 2003 today.
What is the best method to clean the used buttons and can they be individually swapped or are they permanently paired? One has a nice Seek and the other has a nice Preset. Same for Mute and Volume. But all are better than my chipped ones.
I also got the 2003 airbag for $25; not sure if there is a realistic likelihood the car wouldn't be totalled if mine deployed, but still: $25 vs $500 new. Has anyone heard of needing to replace a non-deployed airbag? (The horn stops working?)
Old Aug 16, 2020 | 05:03 PM
mykeeX's Avatar
Does anyone have the part number for the wiring harness for a 2002 Monte Carlo steering wheel cruise/seek & set/volume, or know where to get one?
I own a 2002 MC LS and wanted to upgrade the steering wheel cruise/volume buttons. I bought the new buttons and thought that the other 2 connectors for the seek/volume would be inside once I took the airbag out. I was given the wrong information because I can't find them anywhere.
After doing some research I came to realize that its a totally different harness with 4 connectors instead of 2. But can be replaced by just disconnecting the center connector that's just above the steering wheel nut.
I honestly can't find that harness anywhere. So, for the past month 1/2, my steering wheel is still apart while I search for the correct harness.
Could use some help.
Thank you
monte07
FWD Tech Guides '95-'07
Nov 3, 2016 01:37 PM
TorqueEffect
Jan 25, 2016 05:48 AM
Franks 03SS
Jul 14, 2012 02:05 PM
RickCoMatic
Jan 14, 2008 12:45 AM
claude00
Sep 6, 2006 06:59 PM
