Speaker install question
Old Nov 14, 2010 | 09:27 AM
USMCdevildog's Avatar
Default Speaker install question
Has anyone installed Infinity Reference component speakers in the front doors? If so, where did you mount the crossover and the seperate tweeter? I'm looking to install the 6030cs speakers. www.infinitysystems.com/car/products/product_detail.aspx?prod=REF6030CS&cat=COS&ser=REF &Language=ENG&Country=US&Region=USA
Old Nov 14, 2010 | 01:53 PM
jaws2008's Avatar
GOT SPL
Most Have mounted the Crossover next to the amp or on the floor near your foot area for the front doors. You should be able to mount the new tweeter in the stock tweeter location providing its the same size.
Old Nov 18, 2010 | 02:22 PM
Milhouse's Avatar
You can put the xover where ever you want, I think it's best to put it right next to the amp since you'll be able to access it easily should you ever need to make any changes. The tweeter is best mounted within 18" of the mid, the closer the better. You can mount it in the stock tweet location for the stealth look or you can mount it on the door panel, since you're running passive I'd suggest putting it in the stock location.
Old Nov 22, 2010 | 04:34 PM
Thank you for the responses. I ended up installing the lil tweeter where the old one was at. I could not use the crossovers that came with the Infinity speakers because of the stock amp that the monte carlo has. The new radio and speakers do sound better but I think i need to go with an aftermarket amplifier. Are the aftermarket amplifiers performance worth the $$ or is the stock amp just as good? Thanks in advance for the help
Old Nov 23, 2010 | 03:20 AM
sevnfoe's Avatar
If you have an aftermarket deck, make sure you bypass the stock amp. I didn't do that and my new speakers sounded AWFUL! I drove around for two months with $#itty sounding speakers thinking I got ripped off because I didn't know about that.
Old Nov 23, 2010 | 05:34 PM
Thanks sevnfoe for the response. Gettin kinda confused on this amp bypass situation. From what I've read on this forum sounds like I'll by bypassing the amp. How to do it is the question. Can someone help me out on this bypass? I've read some helpful threads here but still not clear on it all. I'd really appreciate the help.
Old Nov 27, 2010 | 01:08 PM
Milhouse's Avatar
IIRC, the 00-03 Montes have an adapter you can buy for like $20 that will bypass the amp quick and easy.
Old Nov 28, 2010 | 11:13 AM
eviling's Avatar
idk anything about amp bypassing, but far as placment, these cars are massive, the door panels are huge, you could mount it in the door panel in the floor, in the paneling somwhere, or by the amp. mine are next to my amps on the smaller fold down half of my back seat. only because my cross overs are rather large. but you can place them anywhere you see fit, and you should have a spot for tweeters in the stock bafels. depending on the generation you have, but the 5th and 6th i think all have spots for tweeters. even if they aren't stock with the car. not awsome speakers thogh, i'd recommend JBL's any day of the week. i love JBL, big fan boy. my sub is a w12GTI mkII and i have 608gti MKII speakers. but you don;'t need to go for there top teir. there lower teir stuff is nice too
Old Nov 28, 2010 | 11:51 AM
i mounted my cross over in the door panel, i did this because i don't plan on changing a whole lot and if i ever do need to its not that difficult to just pull the panel, but i have considered putting them in the trunk when i build my amp rack
Old Nov 29, 2010 | 03:30 PM
Thank you very much for the helpful info. I appreciate it. Gonna go ahead and throw an Alpine amp inside and install the Infinity Reference crossovers inside the doors. But first, just received my fog lamps!! Gonna try to git those installed without causing any arcing and sparking Thanks again for the help
Bxbootlegger
21
Sep 5, 2012 09:20 AM
Emnasty600
Aug 4, 2011 04:24 PM
Wilco
Dec 9, 2009 10:18 AM
sickofsoyo
Nov 26, 2007 09:25 AM
rudecat
Jan 7, 2007 09:22 AM
